Help with 2D contour (cutting off corners)
nealkriegler
Message 1 of 9
nealkriegler
Hi All,
I have a part I'm trying to cut out using a 2D contour.  Its 72mm square, with 17mm radiused corners.  With a less than rigid machine, I can only take side cuts of 0.2-0.3mm at a time. Preparing the stock only 1mm oversized helps, but using a 2D contour, it tries to cut the corners off in one go, as you can see in the first image. Obviously I can do multiple roughing passes to sneak my way to the line and nibble off the corners, but I'd need about 45 passes just to cut out one of these (second image).
Is there a better/faster way to attack the corners?
Regards
Neal
Replies (8)
Message 2 of 9
seth.madore
Turn on Stock Contours, set your passes to a large number, such as 45, and it will trim away all the "air" passes
Seth Madore
Message 3 of 9
Joshua.Aigen
@nealkriegler you could try adding a ramp to the roughing 2d contour, then the tool would ramp down as it cut allowing for a larger step but still only remove a small amount as the tool spirals down. As well if the force is more down then the machine could go a bit faster? not sure how rigid is not rigid.
Joshua Aigen
Workshop Supervisor
Message 4 of 9
nealkriegler
Thank you Seth. Its a lot faster and its attacking the corners first now, which is good. The only thing is the way it takes the corners off is it first nibbles side to side (climb only, lead in and lead out enabled, keep tool down), but after a few passes, it starts going over the corner to start the next pass. Any Idea why? Pics attached of first few passes in blue and then the raise and move passes in yellow.  Contour 3.PNGContour 4.PNG
Message 5 of 9
seth.madore
Hmm, could you share your file so I can see all the settings you have selected?
Seth Madore
Message 6 of 9
nealkriegler
Here we go 😊 Thanks
Message 7 of 9
seth.madore
It creates these passes by offsetting and then trimming the chain as needed. To overcome this issue of "clipping" the stock, increase your lead-in/out values to 2mm, this will allow it to scoot past without touching stock on it's linking move back to the start
Seth Madore
Message 8 of 9
seth.madore
Furthermore, if you WANT it to lift up between each cut, turn off the "Keep Tool Down" button
Seth Madore
Message 9 of 9
nealkriegler
Ah excellent, thank you Seth. That worked great!
Thanks for taking a look.
Cheers
Neal
