Want to get early access to new functionality? Become a Fusion 360 Insider
We've launched a new program called the Fusion 360 Insider. Apply to join and get exclusive early access to next production version of Fusion 360, two weeks before it is released to the everyone else. Along with getting early access, you will also be able to:
Get your hands on new features, before everyone else
You’ll be the first to get what’s coming in next product update: new tech, improvements, and fixes.
Know in real-time when updates are happening, what’s new, and what’s coming
Know, in real-time, when we are deploying an update and what’s coming in the next one, straight from the development team.
Gain exclusive access to the Insiders Lounge and report issues
As a member, you’ll have access to our private Insider Lounge, where you can engage with other Insiders, Autodeskers, and report bugs and issues directly within the same space.
Similar to where Inventor and AutoCAD manage their beta testing communities, we’re using the same platform for this program to host the Insider Lounge. One thing we do want to be clear about: this is not a beta program. This is early access to the next production update release by installing and running a pre-production build.
If you are a content creator, add-in developer, power-user, or just someone who wants to stay ahead of the curve and test new workflows, this is a great opportunity for you to be a part of something special. To join this program, simply apply by filling out the application form along with an NDA. Once your application is approved, you’ll be able to access the virtual Fusion 360 Insider Lounge, install the pre-production build and start testing out the newest features!
>>> APPLY TO JOIN <<<
___
Important: what you should know before you apply:
- You (as a Fusion 360 Insider) are under NDA and Content Embargo
Pre-prod build gives you early access to Fusion 360's next product update, 2 weeks before we release it to the general public. Since this is pre-released software, you are legally under NDA and all new features and functionality are under embargo until the product update goes live to the general public. If you are making content based on new pre-prod functionality, do not share externally until we deploy the product update to the general public.
- Installing & Uninstalling
Pre-prod build can be installed along side your existing production version of Fusion 360, but we recommend that you replace the production version with pre-prod. We recommend that you uninstall the production build and install the pre-prod to avoid confusion. If you un-installed Pre-prod and wish to re-install pre-prod, you must use the installer links found in the Installer page under Resources.
- Impact to Collaboration / data backwards compatibility with production build
When you work in pre-prod, you are working with your existing Production data. If you are collaborating with people with production builds, they will not be able to access your pre-prod designs. This is because designs saved on pre-prod are not backwards compatible with production versions. (This will only happen for 2 weeks since the general public will catch up to pre-prod by then).
- You need to be actively using the pre-prod build to remain as a Fusion 360 Insider
Since this is an exclusive program, we have limited spots available, and want to assure that Fusion 360 Insider are getting the most out of the program.
