Help optimizing simply toolpath. Project is pecking instead of cutting smooth.
longshotsystems
Message 1 of 15
longshotsystems
Curious what my issue is here. Using a project toolpath, and when cutting the oval you can see it's pecking in many areas rather than just running a smooth oval. Is this a factor of the SVG file it's using not being smooth, or something else?
Thanks!
Replies (14)
Message 2 of 15
leo.castellon
Kind of hard to diagnose the issue when we can only see a picture, we have no idea what settings you are using. For better help, please attach your file.
LeoC
Message 3 of 15
longshotsystems
Attached. Thanks!
Message 4 of 15
leo.castellon
If I had to guess, i would suspect it is because of these overlapping lines in the oval:
Perhaps try to modify your sketch by trimming the overlapping sections or delete the oval part of the sketch and draw a new oval.
LeoC
Message 5 of 15
HughesTooling
Pretty nasty sketch you're trying to use! I guess a conversion from a picture, can you share the picture you used to create the sketch. Also what software did you use to convert to a sketch?
Mark Hughes
Owner, Hughes Tooling
Message 6 of 15
longshotsystems
I used Adobe Illustrator and Image Trace. It was a large 2600px file, so figured it would have done better, but I guess I should inspect it closer in the future. https://commons.wikimedia.org/wiki/File:Ford_1927-1957_Logo.svghttps://commons.wikimedia.org/wiki/Fi...
Message 7 of 15
HughesTooling
Is the attached file any help? I added a sketch with a smoother conversion.
Mark Hughes
Message 8 of 15
HughesTooling
File with CAM updated attached.
Mark Hughes
Message 9 of 15
longshotsystems
Waaaay smoother! What did you do to  clean it up so I can do that next time?
Message 10 of 15
HughesTooling
I used a different program to convert the image on the page you linked. For the file attached before I used an addin in Rhino3d to create a DXF.
I've attached a SVG file to this post I did using inkscape that looks pretty good as well. Here's a link to a tutorial on doing this in inkscape.
Mark
Mark Hughes
Message 11 of 15
HughesTooling
@longshotsystems If you work with imported SVGs you might find this video useful for scaling to the correct size.
[video]
Mark Hughes
Message 12 of 15
longshotsystems
Between the SVG and DXF formats to import line-art is there a preferred/higher quality option?
Message 13 of 15
HughesTooling
DXF probably has a higher accuracy but it will depend on the quality of the conversion. All really depends on what program creates the DXF\SVG.
Mark Hughes
Message 14 of 15
longshotsystems
I'll have to check out inkscape and also look into Illustrator more to see if there are ways to refine the conversion more. Cheers!
Message 15 of 15
HughesTooling
This might be the problem. Using an image that's too big then shrinking after conversion might be picking up too much detail. I only used the 800x446 image
Mark Hughes
