Linking Z Low Settings
M&GToolWorks
M&GToolWorks
I can't seem to find this anywhere to edit, other than the "compare and edit" page. It does not appear on the linking page.
I am getting different results for what appears to be the same settings.
bottomHeight_value - tool_cornerRadius
If I select one and then the other I cannot edit them, if I select the other and then the first, I can edit them? They give different results, and as such, different times for the exact same operation, just opposite sides of the part.
Unfortunately this is a customers part, so I cannot share the model/file.
brad_francola
Hello.  Can you make a generic file demonstrating the problem?  It would be easier to help if we could see an example.
