Change default setup sheet configuration to my custom config?
simspacetn
Message 1 of 17
simspacetn
Is it possible to set a custom setup sheet configuration as the default?  I created a custom setup sheet configuration.  I'd like that to be my default setup sheet configuration, so that I do not scroll to the bottom past the several predefined configurations to select my custom configuration.
Replies (16)
Message 2 of 17
simspacetn
Just wondering if it is possible to set a custom setup sheet configuration as the default? If so, would someone please  point me in the right direction? Thanks!
Message 3 of 17
seth.madore
We have three versions of Setup Sheets (unfortunately). Which one are you referring to, and could you toss up a couple images so we can better understand? (a screen recording would be superb)
Seth Madore
Message 4 of 17
simspacetn
Sorry for the delayed response @seth.madore. Attached is a screen recording of what I am referring to.
Thanks!
(view in My Videos)
Message 5 of 17
simspacetn
Bumping this to see if what I'd like to do is possible.
Thanks!
Message 6 of 17
simspacetn
@gautham.kattethota any chance you can add this default setup sheet configuration idea to the backlog as well?
(See my screen recording above)
Message 7 of 17
seth.madore
This may be possible, let me chat with some folks that might know. If at all possible, it's likely going to require editing an .XML file, which is something you'd have to do each update.
(oh, and "Configurations" from the Design environment are totally different from Setup Sheet Configurations as well as totally different development teams associated with those areas.)
Seth Madore
Message 8 of 17
simspacetn
Thanks for looking into that @seth.madore!
Message 9 of 17
seth.madore
Sad to say, this is not possible in any fashion 😞
Seth Madore
Message 10 of 17
simspacetn
Thanks for looking into this @seth.madore
Message 11 of 17
dkumpf
@simspacetn Related questions: How did you create your custom configuration in the first place? I am looking to do something similar but am a little confused by all the setup sheet generation options (Setup Sheet button, Right click on NC program and select setup sheet, right click on an actual setup and select setup sheet, Create a separate NC program that uses one of the setup sheet posts). Not one of these options does exactly what I want but if I could create a custom configuration I think that would be the best option!
Message 12 of 17
simspacetn
@dkumpf, I'll have to get back to you on that.
Message 13 of 17
simspacetn
@dkumpf, below is a quick video of how to create custom configurations.
However, this is an Insider option. You need to be a member of the Insider Program to access this feature. Membership is free, but it does involve an application process. You can apply here: https://feedback.autodesk.com/key/Fusion360Insider
First you will have to enable this feature.
  1. Open preferences.
  2. Select preview features.
  3. Scroll down to find and enable "Setup Sheet Configurations."
Here's the video showing how to create a custom setup sheet configuration.
(view in My Videos)
Message 14 of 17
milan.blagojevic
 Thanks for this update,
But now, question is how to define which configuration to use ?
Even if I save custom configuration, by clicking on Setup Sheet to export, only detailed  (default) is exported.
How to change to use other custom one ?
Message 15 of 17
nubrandao
If you create sheet by NC
With will appear your configuration
Message 16 of 17
simspacetn
@milan.blagojevic below is a video showing how I access my custom setup sheet configurations.
These are the step l use:
  1. Right click on a Setup in the manufacturing workspace.
  2. Create an NC program.
  3. Right click on the new NC program and choose setup sheet.
  4. Save/Publish the set up sheet, then the setup sheet will be displayed.
  5. In the configuration drop-down, I choose the custom setup sheet configuration I created.
Note that the style/design of the setup sheet created from the NC program context menu is completely different than choosing "Setup Sheet" from the setup's context menu. I personally think it's a better design.
Here's my video:
(view in My Videos)
Message 17 of 17
dkumpf
@simspacetn Thanks for the explanations! I did not realize it was a preview feature so that was my first problem.
