Tool path to face a surface using c axis rotation instead of X and Y
dbroz
dbroz
I am trying to find a way to face a surface in a spiral pattern using the c axis on a rotary rather than X and Y movement. I have the machine extension but have not found a tool path that works. Any help would be appreciated.
Doug
marcus.toepke
I think it is possible, but only with hard and drastic reprogramming a post processor!
But I'm not 100% sure!
a.laasW8M6T
What machine do you have?
The haas post supports an action command "usepolarmode" which can do what you want with say the spiral toolpath
Andrew Laas
Senior Machinist, Scott Automation
marcus.toepke
hmmm I understand it this way that he want that the C-Axis turn around an the tool come every turn more near the center.
The polar output isn't the problem or I understand it totally false!
I think you can do this simple with manual programming.
a.laasW8M6T
Hi Marcus
this does actually do exactly what is required, see video for demonstration and sample file.
Andrew Laas
marcus.toepke
Very nice!
