CAM output
CAM output
twickmanHZ4PK
Message 1 of 41
CAM output
twickmanHZ4PK
sorry if this a noob question, but how do i get a toolpath i generated in 360 out to my CNC? i have watched a few tutorials, and don't see that part anywhere. any help would be greatly appreciated!
Thanks.
Replies (40)
Message 2 of 41
jeff.walters
Most people use a thumb drive or the network. If you can use those options then you can find a good DNC package and send it that way.
Jeff Walters
Senior Support Engineer, CAM
Message 3 of 41
twickmanHZ4PK
Thank you, i guess i should clarify the problem. I cant seem to find a way to save the code to a file? Is there a trick?
Tony Wickman CTPO
C.E.O Freedom Fabrication inc.
815 north Main St.
Havana Fl. 32333
850.539.4194
800.304.3733
Www.freedomfabrication.com
Fax 850.539.4195
Sent from my iPhone
Message 4 of 41
HughesTooling
Have you got as far as pressing the post process icon?
Mark
Mark Hughes
Owner, Hughes Tooling
Message 5 of 41
twickmanHZ4PK
Yes sir.
Tony Wickman CTPO
815 north Main St.
Havana Fl. 32333
850.539.4194
800.304.3733
Fax 850.539.4195
Sent from my iPhone
Message 6 of 41
HughesTooling
You are making this hard work. What are you seeing can you post a screen grab of how far you've got. If you've pressed the post icon on the next dialog pick the post for your machine then click ok you should then get a save dialog, just pick a location to save to and enter a name.
Post Dialog pick your control under Post Configuration and pick an output folder
Save Dialog, pick folder and file name and save..
Mark.
Mark Hughes
Message 7 of 41
twickmanHZ4PK
Ill post a screen grab in the am. It asks me to pick a folder to save it to, but greys out all the possible folders.
Tony Wickman CTPO
815 north Main St.
Havana Fl. 32333
850.539.4194
800.304.3733
Fax 850.539.4195
Sent from my iPhone
Message 8 of 41
daniel_lyall
I will add a vid @twickmanHZ4PK soon
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 9 of 41
twickmanHZ4PK
Thank you!
Tony Wickman CTPO
815 north Main St.
Havana Fl. 32333
850.539.4194
800.304.3733
Fax 850.539.4195
Sent from my iPhone
Message 10 of 41
daniel_lyall
here you go http://autode.sk/1WbdN4p
Daniel Lyall
The Big Boss
Mach3 User
Message 11 of 41
twickmanHZ4PK
here is a screen shot of the file i was able to save, as you can see it is failing to write. sorry, im not very smart.Screen Shot 2016-04-06 at 9.45.22 AM.png
Message 12 of 41
dave.anderson
Seems that the ISEL is a Metric Only post. You can design in any unit, but you'll need to change the Unit in the Post Dialog box from 'Document Unit' to 'Millimeter'.
Dave Anderson
Sr. Support Engineer– CAM
Autodesk, Inc.
Message 13 of 41
twickmanHZ4PK
Hmmm.... Im running a techno isel 3 axis router. Is there a more appropriate post processor?
Tony Wickman CTPO
815 north Main St.
Havana Fl. 32333
850.539.4194
800.304.3733
Fax 850.539.4195
Sent from my iPhone
Message 14 of 41
HughesTooling
Does the machine support Inch\mm with G20\21. modifying the post should be easy enough. Have you got an example g code file that works you can upload, if the file extensions blocked by the site just change it to txt.
Mark
Mark Hughes
Message 15 of 41
twickmanHZ4PK
here is a file i have run successfully from cambam. i did try several other post processors just to see what happens. i downloaded the techno post processor but dont know how to install it.
Anthony Wickman CTOP
815-b north main st.
Havana Florida 32333
1.800.304.3733
WWW.freedomfabrication.com
Message 16 of 41
HughesTooling
The file didn't seem to attach, I don't know if you replied by email, if you did attachments don't seem to work with email replies. As for where to store a custom post, are you using a mac or a PC?
Mark
Mark Hughes
Message 17 of 41
Hello
I have a similar problem.
When generating code, I get an error code page UTF -8 .
Message 18 of 41
twickmanHZ4PK
I am using a mac, i'll try to attach that file here.
i found a techno post processor but when i try to upload it to my cloud posts, it fails.
Message 19 of 41
HughesTooling
I've done a post here that explains setting up cloud libraries and how and where to save on A360.
Mark.
Mark Hughes
Message 20 of 41
twickmanHZ4PK
thank you! thats what i did. maybe the file is bad? this is what i used,
