4-Axis Milling with Rotation about c-axis
06:32 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm looking to do 4-axis machining for a very specific application. This application requires x,y and z movement as well as rotation in the z-axis (or c-axis rotation). This means that I need the part to rotate about the same axis that the drill bit is in.
I am new to Fusion, but any rotation seems to be turning it into a lathe, or x/y-axis rotation. Is it possible to have the drill in the same axis as the rotation part?
NOTE: For this application, I need to rotate in z, followed by a straight line in x/y, and then rotate again. Therefore, it is not pure rotation in the c-axis as there will be linear movement in addition to the rotation.
Thank you for your help!
