Machine configuration broken?
john.h
john.h
I noticed today that the option to select a machine configuration has disappeared with the latest update. I have started to rely on this for keeping track of A-axis position when creating new operations.
Am I missing something or is this really gone?
Thanks for all your hard work,
John
Hi .. I join this same question ..
I am configuring a post-processor and not being able to select the machine the same fault when not knowing if it is a 3-axis machine or a multi-axis machine ..
Is it a fault, was it definitely eliminated or is this configuration going to come back?
If you do not return ... is there another option to configure the type of machine?
Thank you !
I found a solution in the forum and it worked for me as they say there ..
https://forums.autodesk.com/t5/fusion-360-computer-aided/assigning-machine-after-new-update/m-p/8531...
