- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I opened up an old projects and components, wires and ref des were not snapped to grid which made it almost impossible to add more components that would be on the grid. I was able to select all and align components to grid, but how can I do the same for the reference designators which are still in their initial positions? It would also be helpful if there was a way to snap everything to grid at once including the wires, if possible, but if I had to manually rewire everything that is less of an issue that manually changing the properties of each ref des (and resistor/cap value for that matter) to be set at a position that is a whole integer.
Is there a script that can go through each object including refdes/value/text and move them to the nearest integer position of inches? Or an easier way to select all and get everything to snap to grid? Thanks in advance.
