Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
SMD Pads Soldermask in 3D Preview
1 REPLY 1
puresoft
142 Views, 1 Reply
When I create a library with SMD pads, the 3D preview shows soldermask over the smd pads as shown below. However it seems to preview ok in CAM preview. Can you confirm whether this is only a visual artefact of the 3D preview, or whether the soldermask is really covering the SMD pads if I sent it for manufacture?
I saw some similar post from last year that seemed to be marked as solved, but it seems this issue is still here?
1 REPLY 1
puresoft
in reply to: puresoft
I viewed the exported CAM data in a free online viewer at PCBWAY and see that the soldermask is there, so it appears only to be a visual artefact. Would be good to get it fixed though to present the board correctly in 3D preview.
