Collaberative working
robert.martinUKYP4
robert.martinUKYP4
Starting a large project for Electronic design. There are 2 engineers assigned to the project and we are about to start schematic capture. Is there a way for 2 engineers to work collaberatively on a project. Whilst testing, we found no obvious way to do this and as it's such a large project, having to split it up and copy/paste in would cause all sorts of issues later down the line
jorge_garcia
Hi @robert.martinUKYP4 ,
I hope you're doing well. It isn't possible for two engineers to be working in the same file at the same time, like you would say a Google Doc. Once we have Design blocks available in Fusion360 this will be easier but for now being able to clearly separate the design and then doing a copy and paste is the way to go.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
