In the current version, how can I open these type of files in Fusion 360.
I can export these to SCH and PCB, but I can not open in Fusion.
I see some useful article here:
But I can not sign in, or there is some error so I can not see it.
Any feedback is helpful.
Solved by wes55ETD. Go to Solution.
Solved by jorge_garcia. Go to Solution.
Hi @wes55ETD,
I hope you're doing well. I think that leads to a dead link, it doesn't work for me either. There really isn't a good way to import Alitum designs into Fusion 360. You'll see posts of importin ACCEL-ASCII files which technically work but there is no way to get them to be consistent.
Let me know if there's anything else I can do for you.
Best Regards,
The method I ended up using was exporting gerber files from altium, and creating a pcb from those files on fusion.
