I am trying to change the radius of one circle signal, after the signals on the board all join as if there was a polygon fill!!! I need help understanding how to replicate this feature as I had to import the gerber files. Here is the image of what we need from another pcb design software.
Thank you for any help on this!
@jorge_garcia I cant seem to find any reason this would be.
Solved by wes55ETD. Go to Solution.
Hello @wes55ETD,
I hope you're doing well. Did you do a gerber import? In that scenario you don't have a proper netlist and connectivity information. Which might explain why the fill is weird.
It's hard to modify a design when you just get gerbers because there is so much data missing. With all that said I'm not sure why the polygon is filling the whole design. Would you be willing to share the design or a portion of it for review?
You can export the design and post it to the forums or send it through email.
Let me know if there's anything else I can do for you.
Best Regards,
I can not share the design exactly, but I fixed it by first deleting the polygon fill, then doing the new geometries required.
Thanks Jorge, you're always on it!
