Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
No value input for capacitor
6 REPLIES 6
1179 Views, 6 Replies
I put the value (1k) for a resistor here:
Where do I put the value (e.g. 0.1uF) for a capacitor?
6 REPLIES 6
rbeyerCLBSZ
You should also be able to right click the part and select "Value". A small dialog will pop up asking you to input the value you desire.
The dialog looks strange though. Capacitors should be named "C" not "U$1", which makes me think that you are using a capacitor out of a library that has some issues...
jorge_garcia
Hi @Anonymous,
I hope you're doing well. In addition to what @rbeyerCLBSZ mentioned it's possible you have the Value radio button in the device editor set to off. If it's set to off then by default it doesn't have a value. That might explain why the dialog looks weird.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
richardHQA8V
in reply to: jorge_garcia
I have the same issue. I appreciate what you're saying @jorge_garcia , however this is one of the libraries provided with Fusion 360, so presumably we shouldn't just go around editing the parts (if we even can?). I've attached a screen cast so that you can clearly see the problem which @Anonymous  and myself are experiencing.
Kind regards,
Richard.
16c46409-aad0-4610-a210-796fb3a879b9,640,650
richardHQA8V
in reply to: richardHQA8V
Screencast seems to not have worked in that last post...
jorge_garcia
Hi @richardHQA8V ,
I hope you're doing well. Thank you for the screencast, it confirms what I thought the issue was. The way the part is designed in the library is not the best for a passive component. I'll report this to our library team.
In the meantime when the message pops up click Yes and you will be able to change the default value. In the device editor this component was set to have it's value set to OFF which means the value becomes the name of the device and by default the user can't edit it. You can override that by clicking Yes in the dialog that pops up.
Best Regards,
Jorge Garcia
Hi @rbeyerCLBSZ , @richardHQA8V , @Anonymous ,
Hope all is well.
The embedded Capacitor have been updated to allow setting value some time ago already. You could try to have a look.
Hi @ionkozokar21 , sorry to hear that you have the trouble.
The Fusion 360 latest version is 2.0.9305, could you please upgrade your Fusion to latest version and have a try again? As I know this has been updated for some time ago already, not sure why you still have the problem.
Looking forward to hearing back from you.
Sorry for any inconvenience.
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
