Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Use DXF file as template for custom component footprint
0 REPLIES 0
Message 1 of 1
389 Views, 0 Replies
I am pretty familiar with EAGLE and have designed a few boards with it in the past. Today I decided to give Fusion 360 a shot. I am in the process of creating a board that will be used to connect multiple off-the-shelf boards such as (Arduino Mini Pro, motor controller, and wireless transceiver). The motor controller has a bunch of different ports and does not follow a typical pattern with that being said I do have access to a dxf file that specifies the drill locations on the board.
In the past I would just place this dxf file in the tplace layer of EAGLE and use it as a template to create my custom footprint. However, I can not figure out for the life of my how to add a dxf file when creating a footprint in Fusion 360. I did a bunch of googling and searching these forums and did not come across anything.
Labels (3)
0 REPLIES 0
