I have imported an EAGLE .brd file into Fusion.
In general it worked pretty well except that polygon pour for the ground plane is not drawing thermal spokes. It's not working on either through-hole or SMD pads.
I have tried re-drawing the polygon pour. I have tried creating a new net class. Ticking / un-ticking thermals doesn't change anything.
Any ideas?
Solved by duncanBC5DV. Go to Solution.
Solved by panpan_fan. Go to Solution.
Hi @duncanBC5DV
I hope you are doing well!
I do some basic tesing and it works for me.
So I guess it may be related to some settings or your specified file.
Would you mind sending me your file to double check?
I will send my email address to you as a private message.
Panpan Fan
