Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Import scr file (or any file for that matter)
11 REPLIES 11
Message 1 of 12
1978 Views, 11 Replies
Hi All,
I am trying to import a part library that was saved as an Eagle scr file. I can't find out how to do it. Does anyone have any clues?
Thanks in advance,
Rob
11 REPLIES 11
Message 2 of 12
Spragnut
Create a new library and type script into the command box and it will bring up a dialogue, select eagle and browse for the script. It should then run it..
There looks to be a few bugs, like when trying to add a footprint script you have to first create a temporary footprint for it to work, otherwise it throws up errors.
I think it works fine for a complete component though.
Message 3 of 12
in reply to: Spragnut
I can't find how to create a new library. The function does not seem to be available.
I am getting this error "Error updating libraries" in some different places. See the screenshot. Could that have anything to do with it?
Rob
Message 4 of 12
Spragnut
There was an issue before the last bug fix where this occurred but I thought it had been fixed, although there is another recent post saying the same so maybe it's returned.
It looked like it was caused by being logged out but it not saying so in Fusion, logging out and back in fixed it.
Might be worth a try.
The whole program is fairly buggy so unless you really want to use it, it might be worth sticking with Eagle for the time being.
Message 5 of 12
Can I still use Eagle? I will give it a try.
This Fusion 360 looks promising but is frustratingly buggy.
Rob
Message 6 of 12
jorge_garcia
Hello @Anonymous,
I hope you're doing well. Yes, you can still use EAGLE. It's included with your Fusion360 entitlement.
Let me know if there's anything else I can do for you,
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 7 of 12
armature81
Hello
i have same problem as i don't know how to upload scr file
Message 8 of 12
I have the same problem, it seems that the newest form of Eagle/Fusion does not have the same workflow to import a library from Ultra-librarian (.scr) which is incredibly frustrating. Does anyone have a solution for this?
Message 9 of 12
jorge_garcia
Hi @Anonymous ,
We are in talks with Ultra-librarian to get these things fixed. In the meantime, go into the SCR file and make sure all the commands end with a semi-colon. That's the problem with the files, EAGLE tolerated this but it was incorrect. Fusion360 will not tolerate this and that's where the issue lies.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Message 10 of 12
dheco
There is no way in the current version of Fusion360 to create a new library therefore no dialog to enter the script to import the scr. There must be a way to run the script!
Message 11 of 12
jorge_garcia
Hi @dheco ,
I hope you're doing well. In Fusion 360 you can make a new library, by clicking File > New Electronics library. In any of the editors type Script and press enter in the CLI. Then you can browse to the script to import that part.
Best Regards,
Jorge Garcia
Message 12 of 12
HelenChen-ElectronicsQA
Hi @Anonymous , @dheco , @Anonymous , @armature81 ,
Keep you be updated that now you are able to download the library as .lbr format from ultralibrarian and open it in Fusion 360 directly now.
Please choose Autodesk > Fusion 360 PCB when you are downloading the library.
And additionally, now if you download the library script format as EAGLE 6 file, you could switch to Automate Tab in the library editor > click Run Script icon > Browser the downloaded script file to run > Then the library will be imported successfully in Fusion 360 too.
Hope it helps.
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
Technology Administrators
