Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Dont open 3D File on Startup
2 REPLIES 2
danielboe63PST
118 Views, 2 Replies
if I use Fusion for Electronics (before I used Eagle) the 3D File always opens with the project. Its a massive effort to load this even on a good computer and most of the time it is absolutley not needed.
Is there a way to open only PCB and Schema File and dont open the 3D ? At the moment I load my project, it takes time and then I need to close the 3D manually.
Thanks for the help and best regards
Daniel
2 REPLIES 2
ritste20
in reply to: danielboe63PST
Currently, I don't believe there is an option to disable opening the 3D PCB document because Fusion is attempting to keep all documents synced with each other. I agree opening the 3D file is generally unnecessary because you usually have to push changes from the 2D board file anyway.
If this is a large project that you know will have many edits to perform, you could always unlink and delete the 3D file until such a point in time that it would be needed for something like enclosure design.
Maybe @jorge_garcia can provide additional options.
Steve Ritter
Manufacturing Engineer
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
Hi, thanks for the answer. Unlinking "solved" the problem but still I think its not meant like this. I think a feature to not open 3D for PCB Designers should be default.
