Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Edit net classes
1 REPLY 1
infinitemach
564 Views, 1 Reply
Edit net classes
Is there an easier way to edit net classes without having to select a net and access the net classes from the inspector?
1 REPLY 1
mtl_asm
in reply to: infinitemach
you can type "class" in the command line to bring up this window without having to go  to the inpsector
you can also just define the net classes from teh command line by passing arguments after the word "class".
if you reuse classes across many designs it may be helpful to write a script which just defines all the classes you want via the class command.
you can see the syntax by looking up "class" command in the fusion manual.
CLASS
Function
Define and use net classes.
Syntax
CLASS
CLASS number|name
CLASS number [ name [ width [ clearance [ drill ] ] ] ] [ number:clearance .. ]
See also Design Rules, NET, SIGNAL, CHANGE
The CLASS command is used to define or use net classes.
Without parameters, it offers a dialog in which the net classes can be defined........." and so on
Technology Administrators
