Is there an easier way to edit net classes without having to select a net and access the net classes from the inspector?
Solved by mtl_asm. Go to Solution.
you can type "class" in the command line to bring up this window without having to go to the inpsector
you can also just define the net classes from teh command line by passing arguments after the word "class".
if you reuse classes across many designs it may be helpful to write a script which just defines all the classes you want via the class command.
you can see the syntax by looking up "class" command in the fusion manual.
CLASS
Function
Define and use net classes.
Syntax
CLASS
CLASS number|name
CLASS number [ name [ width [ clearance [ drill ] ] ] ] [ number:clearance .. ]
See also Design Rules, NET, SIGNAL, CHANGE
The CLASS command is used to define or use net classes.
Without parameters, it offers a dialog in which the net classes can be defined........." and so on
