Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
[beginner] Simple board with only traces and pads
3 REPLIES 3
jaco.waes
199 Views, 3 Replies
I am making my first steps in electronics and i want to design a simple pcb that connects multiple  WS2812B led strips.
To simplify, let's say i want to make a small pcb with two times 3 solderings pads and traces between them. There are no components itself on the board. The strips are adjecent and soldered to the pads on the pcb.
There is a WS2812B led component in the library with 4 pins, for simplicity this component can represent a whole strip. But actually resides twice out of my PCB.
Do i place those in my schema ? Or i create a component that represents the 3 soldering pads ?
Labels (1)
  • PCB
3 REPLIES 3
jorge_garcia
in reply to: jaco.waes
Hello @jaco.waes,
Welcome to the wonderful world of electronics! In this case your first design is a good simple choice, but I would still recommend making a schematic. The schematic will just have 2 connectors connected together. In this simple case the schematic is not strictly necessary but it is a good habit to get into.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
jaco.waes
in reply to: jorge_garcia
Does that mean i have to make a '3pin connector' component with the corresponding footprint and use that in a schema ?
jorge_garcia
Hi @jaco.waes,
Correct, the from the available libs you can bring in the old EAGLE libs. The pinhead library has some good examples of how such a connector could be made.
Best Regards,
Jorge Garcia
Technology Administrators
