I have a 1206 smd resistor in bottom layer and a tactile switch on top of it on top layer. I can't select the bottom resistor or it's attributes like name. Help will be appreciated.
There are several solutions:
-If the wrong items is selected under your mouse, you can click the right mouse button to toggle trough all the items at that location.
-Disable the top layers (temporarily) to reach out for the required component at the bottom layer.
-Use the selection filter to narrow down you required selection.
-In the design manager tab search for your component, click on the component in the list and it will be highlighted on the pcb.
