Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Cant select a component on bottom layer
1 REPLY 1
soumya.chakraborty
79 Views, 1 Reply
I have a 1206 smd resistor in bottom layer and a tactile switch on top of it on top layer. I can't select the bottom resistor or it's attributes like name. Help will be appreciated.
1 REPLY 1
There are several solutions:
-If the wrong items is selected under your mouse, you can click the right mouse button to toggle trough all the items at that location.
-Disable the top layers (temporarily) to reach out for the required component at the bottom layer.
-Use the selection filter to narrow down you required selection.
-In the design manager tab search for your component, click on the component in the list and it will be highlighted on the pcb.
