How to stop email otp from autodesk for autodesk login even 2 step verification is off
anuradha.bodke
Message 1 of 11
anuradha.bodke
Hello Sir,
As we had autodesk account with email of  our management member, and many times they are not available in  the office , as per new login process for autodesk we have to enter code which is email by autodesk on register mail ID,
and  my 2 step verification is off so I want to know how to stop email otp from autodesk for autodesk login even 2 step verification is off,  other alternative for login using only email Id and password , same as previous process
Please share if any
Thanks in Advance
Replies (10)
Message 2 of 11
RajkumarIlanchelian
@anuradha.bodke This email OTP is a one time requirement. It will not ask you again.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 11
Evert_2N3055
Hi Rajkumar,
Unfortunately it's not asking the OTP ones.
2 minutes ago I had to enter it again. That was for the 5e time.
Very annoying .
Message 4 of 11
RajkumarIlanchelian
@Evert_2N3055 Can you direct message me your email used to register for Fusion, please? I want to check with our internal team.
Autodesk Fusion
Join Fusion Insider
Message 5 of 11
CGBenner
@anuradha.bodke @Evert_2N3055
Hello, were you able to resolve these questions?
Chris Benner
Message 6 of 11
anuradha.bodke
No , I have not got answer
Message 7 of 11
Evert_2N3055
I don't have answer from @RajkumarIlanchelian also yet.
His team had to look at the issue. It's not normal behavior to enter the OTP that often he confirms
Message 8 of 11
RajkumarIlanchelian
Customer support should have gotten back to almost all of you on your cases. Please let me know if they have not contacted you or if your case ID is still not resolved.
Autodesk Fusion
Join Fusion Insider
Message 9 of 11
Evert_2N3055
No contact with me from customer support.
And problem not solved, had to enter Otp 3 minute ago again.
Message 10 of 11
RajkumarIlanchelian
@Evert_2N3055 My apologies. I posted the above post in the wrong thread. This was meant for another thread .
Regarding having to enter OTP, I checked with the team and here is what I am told. If you do not have 2FA enabled, you will have to enter OTP on every login (now there is an option that you can do a check box that gives you an option to nt ask for OTP for 30 days).
Autodesk Fusion
Join Fusion Insider
Message 11 of 11
c_wearingCBRT2
Why are users being forced to us 2FA or email OTP? Is Autodesk planning to add an option for users to disable these features?
