ECAD Fixes in the May update
jorge_garcia
Autodesk Autodesk
jorge_garcia
Hello to the Fusion ECAD Community!
We greatly appreciate you taking time out of your busy schedule to notify us of the issues that you find in Fusion, and we would like to show that appreciation!
In an ongoing effort to increase our transparency as well as our communication with you, we're continuing with our initiative of calling out all the Forum Reported bug fixes that are included in each update. The list below comprises all the issues that have been raised by our engaged community. So, without further ado, here is what we're going to see in the May 2024 update (creator of forum thread and the thread itself, in no particular order):
ECAD
@michal.horacek
Function Place Component - Description and scale should be improved
@b.legnini
Fusion 360 PCB Buried/Blind Via should no longer block polygon thermals
@beananimal
We’ve fixed the directory issue for Electronics folders on Mac
@sergeQJMQW
Eagle 9.7 file format
@crgmakes
Better visibility/selection of Component Origin layer
@chris_cummingsDT
Improvement of the “highlight” behavior for new selections
@troydjEPMYB
How to disable new selection feature
@shawn3WMTV
Improvement with Spice initial Conditions
@crgmakes
Double clicking should now expand Details when choosing different layers
@peter4U7PP
Better switching command (hotkey) when component selected
@chuck_toddN7PTC
Prevent Stich Vias from overlapping
@wayneweeks
Via stitching should no longer cause thermals to disappear
@oleksiymoroz7
Via Stitching should no longer cause Fusion to hang
@v522
Component description should no longer be missing in schematic
@roatchristopher
Edit in Place no longer moves component in wrong direction
@dev2EP8UX
Freezing and Crashing should be reduced
Just as in the March Update, this isn’t to suggest that those are the only fixes that we've included. The list above are the issues specific to the ECAD community; within this update our team has additionally found and closed 150+ different bugs.
Still haven’t seen your issue on the list and wondering if/when it's going to get fixed? Don't hesitate to "bump" the original thread that you created, and I'll be happy to chase down the status of your issue!
Thanks for contributing to what makes the software truly great!
Click here to see: March Release Community Patch Notes,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
chris_cummingsDT
Thanks, Jorge!
I am testing the latest May update to the highlighting, recommended by Panpan. So far, it has several improvements and more stability / less jitter. I will report back directly to Panpan, if anything comes up.
