Trouble with parametric constraints and linear patterning
biribonwajudith
biribonwajudith
I am relatively new to parametric design and I am having trouble with it. In the picture attached, I have set length, width and number of lines(for patterning purposes) as the parameters.
However, after patterning, I would like to trim away part of the patterned lines so that they stop at that line across the width. However every time I do that, the parameter relating to number of lines no longer works. Please help. Thank you
o.briggs
Hi @biribonwajudith
The root of the issue is that the pattern creates constraints that define where the sketches are located. By deleting the top half of the lines you remove that constraint (you might get an error telling you this). This means that the sketch is no longer defined by the pattern that you did, and therefore the parameters have no effect.
I am trying to find a way to make this work and will get back to you with any ideas, but for now I want to ask what you want to do with it after you have completed the sketch?
Could you leave the lines as they are (without trimming) and just select the profiles that you need from the sketch?
is it possible to do the pattern operation with the modelling pattern tool rather than at the sketch level?
Oliver Briggs
Community Platform & Operations Manager
Please 'Like' posts that are helpful.
If a post answers your question then feel free to click the 'Accept Solution'
biribonwajudith
I am making parametric designs for CNC machining. Attached is a sample, the
challenge is many lines are crossing each other
o.briggs
Apologies but I cannot see your attached file.
An image or file of your completed 3D model (ie exactly what you want to end up with once manufactured) would be very useful!
Oliver Briggs
