DOUBT:
DOUBT:
ShubhamG_621
DOUBT:
ShubhamG_621
Why am I getting a sketch error after editing the joint limits to 0?
1.
2.
3.
o.briggs
I am not sure why it is throwing up a sketching error. Potentially it is referencing the joint limits in the background in a sketch and because both are overlapping it doesn’t know how to have a dimension that has length zero? I am not sure honestly. However, my question is why you want a joint limit of zero? This would mean that the slider joint cannot slide and is effectively just a rigid joint, so could you not set the motion type to be rigid and not have to use joint limits in this instance at all?
Oliver Briggs
Community Platform & Operations Manager
Please 'Like' posts that are helpful.
If a post answers your question then feel free to click the 'Accept Solution'
ShubhamG_621
Actually I was practising Fusion 360 and just tried to do some random things and then i came across this error.
Thank you for your response👍.
o.briggs
Ah ok fair enough! Thanks for letting us know! It is very curious as to why it is the sketch that received the error, not the joint!
Oliver Briggs
ShubhamG_621
Yupp!
dan.banach
Hi @ShubhamG_621
Excellent question. The centerpoints of the slot in the sketch (center to center distance) are driven by the distance of the Joint Limits. This was done by creating two axises and projecting each axis on to the sketch. When you change the Joint Limit minimum distance to zero, the slot cannot be computed. As you can see in the screen capture, the when I changed the Joint Limit Minimum distance to -5, the center to center distance of the slot also changed to -5.
Does this help?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
ShubhamG_621
Ook, got it sir👍! Thank you for your response.
