Deployed 2-speed gear box
101210303
101210303
I want to ask how to determine the tangent plane in " MANUAL CONTACTS"Ảnh chụp màn hình 2023-03-28 204411.png
dan.banach
Hi @101210303
Can you tell us more about why you need to determine the Tangent Plane while creating Manual Contacts?
Attaching the f3d file will help us, to help you.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
I need to determine the contact surface of 2 gears for endurance simulation
dan.banach
Hi @101210303
Thanks for the additional information. I'll ask our Simulation team for advice on how to set up this type of simulation.
Could you Export a .f3d file and attach it to this thread?
-Dan
Dan Banach
dan.banach
Hi @101210303
I connected with our Simulation team and they also asked for the .f3d file. The team gave me the attached image that may help. Also stated "For spur gears (probably similar for helical ones), the contact force is always directed in the same direction, regardless of how many teeth are in contact."
Please keep us posted.
-Dan
Dan Banach
