Fusion - Deutsch
Das Forum für alle Fragen rund um Autodesk Fusion (ehemals Fusion 360). Der Ort zum Fragen stellen, Antworten erhalten und Wissen teilen.
CAM Parallel surface extention path
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
k.jannik
256 Aufrufe, 2 Antworten
Hey guys,
I have issues with the 3D CAM operation parallel. I got this surface from a knife that is beeing milled with this operation. Picture 1 shows the actual tool path from the finsihing path with a fine step over. The path itself is fine but I would like to extend the tool path in both directions a few mm (shown in picture 3 red arrows). I know that there is the option "extention" (picture 2) but when I select it, I got the problem shown in picture 3. I just want that the actual tool path is beeing extented, not changing the diraction.
Is there a solution to my problem?
Thanks in advance.
Jannik from Messerlabor
2 ANTWORTEN 2
Nachricht 2 von 3
rewedesk
als Antwort auf: k.jannik
@k.jannik I would do this with an offset surface
1. Make a offset surface
2. Stretching surface
3 Create a setup for this area
Greetings
Reiner
Nachricht 3 von 3
k.jannik
als Antwort auf: rewedesk
Phenomenal! That seems to work.
thanks for your quick help 🙂
Jannik
”AEC
