I use a MacBook air. I work on airplane models and use wood as main material. I need to run simulation I mean static loads etc. FEA on wood. Is there any alternative to fusion 360. (Maybe add wood sim in fusion) What can I use for mac to study wood or i’ll have to get solidworks ?
static test when initiated the wood is described as Non-linear material and fusion can’t run the simulation.
It says some components use a material with invalid properties.
Hello @Anonymous
it will be a bit difficult to study static test on Nonlinear Materials
Because natural properties may-not be same all the time
it may changes from tree to tree :[
@Anonymous wrote:What can I use for mac to study wood or i’ll have to get solidworks ?
What type of analysis would you run in SolidWorks? (trick question)
@Anonymous
But you can set up own material If you have appropriate material properties in Fusion 360.
(We have an option in Simulation environment) Go To: MATERIALS > Manage Physical Materials
