Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Wood simulation on Fusion 360
3 REPLIES 3
3211 Views, 3 Replies
I use a MacBook air. I work on airplane models and use wood as main material. I need to run simulation I mean static loads etc. FEA on wood. Is there any alternative to fusion 360. (Maybe add wood sim in fusion) What can I use for mac to study wood or i’ll have to get solidworks ?
static test when initiated the wood is described as Non-linear material and fusion can’t run the simulation.
It says some components use a material with invalid properties.
3 REPLIES 3
rajeshpolamuri
Hello @Anonymous
it will be a bit difficult to study static test on Nonlinear Materials
Because natural properties may-not be same all the time
it may changes from tree to tree :[
Hi everyone, I am Rajesh. I am graduate of Mechanical Engineering in India. I am passionate on creative works like CAD, Art's, Edits, Designing, Etc..... I am also an Autodesk Student Ambassador. I was always shows my interests on the works. Which makes effective and updating every time, With the modern world.
TheCADWhisperer
What type of analysis would you run in SolidWorks? (trick question)
@Anonymous
But you can set up own material If you have appropriate material properties in Fusion 360.
(We have an option in Simulation environment) Go To: MATERIALS > Manage Physical MaterialsMaterials management.png
