- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have these edges that won't fillet no matter the size or the edge/faces I select. I want to add a small fillet to smooth the transition between the spirally walls and the top but I haven't been able to...
The error is
"Error: The fillet/chamfer could not be created at the requested size. This might be occurring at the ends of the selected edges.
Try adjusting the size or using multiple separate operations. Check that the selected edge chain ends at a sensible position, and if not try selecting more edges."
Here's the f3d file so you can take a look. Attached is the .f3d file if you want to take a look.
Sorry for the component/body structure... I'm still a mess when it comes to organizing the objects and thank you for your help. 🙂
