when will in sketch smooth constraint also be like coincident?
cekuhnen
Mentor Mentor
cekuhnen
you make a spline smooth to a 3D include edge
adjusting the other sketch will make the smooth constraint spline not follow
this only works when: 1. coincident + 2. smooth constraint
makes no sense because smooth constraint has coincident as a requirement so why not include it by default
meaning smooth constraint includes the code for coincident.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
TrippyLighting
Is this in the idea station ?
Hi Claas, I know for one thing there is an issue of exactly what your image is showing, where the spline endpoint handle gets dislocated from the actual spline when another sketch, construction plane etc. is modified to move the desired spline endpoint.  The solution is to activate that endpoint tangent or curvature handle (activating the latter will automatically activate the former).  In your image I can see the tangent handle is not activated, being green instead of blue.  Give that a try and see if that fixes it!
Jesse
cekuhnen
I don't know if this is a bug or not intended to work this way. But I would say this is a bug to me.
May besomebody from AD could join here. Today in a Fusion presentation to a client this happened which was quite embarassing for being parametric.
Claas Kuhnen
It appears to be a bug.  Another way to get the endpoint to update is to actually go into the sketch and adjust any of the tangent handles manually, which at the same time activates it.  But the handle activation before the fact work around is definitely better 😉
Jesse
I should also point out it was @LMD001 that first raised awareness of how editing the spline would update its enpoint(s).
Jesse
jiang_peng
