@0502880
"Still I like to ask you, should there come any shape problems there in the (sharp)corners where two quads meet one if you need to modify the top shape?"
Hmm, that's hard to answer but I feel 99% of the time I would say no there will not be any shape problems. That probably needs some explaining though. The quad section at the top and bottom of the cylinder was separate T-Splines and the edges were welded to the side, so if I needed a different form I could cut that out and replace it with any other form I want. One thing that I don't think most people understand about T-Splines is the rules for combining them are almost the same as the rules for NURBS modeling, but the way you model is like Sub-D. I keep seeing people trying to make finished forms from one T-Spline...as long as the shape is simple this is fine but for complex surfaces you need multiple T-Splines. Once you have these multiple patches of T-Splines you need to understand how to put them together without messing up the overall shape. That's where the NURBS rules come in. Combine this knowledge and you can make anything with T-Splines.
"Then an other question, a little bit philosphical; would you get some advantages to use T-Spline versus straight revolve function in such a rotational body?"
The answer to this depends on your end goal...is the shape going to become something organic or stay a cylinder? Another question to ask yourself is when this becomes a solid or a patch is the surface clean or are there a bunch of faces that are like little slivers that will cause other operations to fail? If I convert this T-Spline (55 Gallon Drum) it gives me a very clean surface. If I revolve it, then it will split it somewhere that is uncontrollable. I prefer to retain complete control over the surface of my models, but that's just me.
"Some users will warn to use T-Splines and "normal" modelling features (fillets etc.) in same body; what is your experience and advice in that matter?"
Almost all of my work uses all available tools (Solid, surface and T-Splines) unless it's what I call mindless CAD work....I hope this answered your question.
Cheers
Phil Procario Jr.
Owner, Laser & CNC Creations
