X axis movement is readas Z axis while performing joint command
kris.chlapek
kris.chlapek
Hi All
Not so sure if i did something wrong or there is a bug, but when I`m trying to apply joint, and then when i move in x +/- then on the joint parameter tab the Z axis moves instead. Video better explains the problem I`m facing.
HughesTooling
Without more info, hard to help. Can you share the design or at least a screengrab.
The XYZ are relative to the joint origin not the document so when you select the second point the XYZ will be like the image below.
Mark
Mark Hughes
Owner, Hughes Tooling
