wavy surface
wavy surface
evou.polcar
Observer Observer
wavy surface
evou.polcar
Observer
Observer
Hello everybody,
I have this shape and want to make the body's surface wavy or make some structures on it. How can I do it? All tutorials I have found were on rounded bodies.
Thank you very much, It's my university project so I really appreciate any help. Best Regards Eva
kacper.suchomski
It seems that this can be achieved by freeform modeling - split into a dense mesh and scale every other vertex to the center.
But as a rule - you should first plan the effect and only then start modeling. This effect is very easy to achieve using Loft. Sketch a wavy perimeter at the top, trim the shape at the bottom and add a Loft wall between the smooth and wavy edges.
Kacper Suchomski
TrippyLighting
As @kacper.suchomski has already explained, this can be achieved using a variety of modeling techniques.
If you can share your model and perhaps an image that looks similar to the effect you want to achieve, that would also be very helpful.
A paper/pencil sketch would also work well.
