Wanted: Method to reduce size of model but keep it proportional.
kepp.andrews
kepp.andrews
I want to reduce the size of a finished model and at the same time, keep the proportions identical. For instance, I have a model that weighs 391 grams and I want it to weigh 320 grams, but I want the design and all proportions to remain identical to the original.
Demonstration model is attached.
Kepp Andrews
Accepted solutions (3)
HughesTooling
Doesn't a uniform scale do that?
Mark Hughes
Owner, Hughes Tooling
kepp.andrews
Mark. I don't even know what that is, but I'll look it up and give it a try. Thanks for the direction.
HughesTooling
Just for a test I took your example that weighs about 303g and scaled it to 500g like this. See attached file.
Mark Hughes
MRWakefield
As @HughesTooling says, use the Scale command.
For the scale factor you'll need to enter the cube root of the mass ratio. i.e. 0.93522857
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
kepp.andrews
Thanks!
