Vertically align components
12:15 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have two components(cylinders) which are not on the same plane or connected in any way. The lower component is grounded and the second component is floating 30mm above it, slightly to the right and at an angle. How do I vertically align the 2 components so that their centres lie exactly above each other and they are parellel to each other?
I have tried:
1) Aligning components - this seems to just align them to be parellel to each other but not centered above each other.
2) Placing joint origins at the centre of each cylinder and then doing align components. This doesn't work.
3) Select the Y axis and the second component and do align components. This doesn't work either, seems like it doesn't align to an axis this way.
Please help
