Fix Position of Toolbars on shutdown.
BrianM_12
BrianM_12
Before I shutdown the computer I minimise the browser tab and open the project data box. During use I have previously put the menu bar out of the way at the extreme top of the screen.
Whenever I load F360 again the bowser bar and the menu bar have returned to their usual position on the screen. Since "the system" remembers default units etc. would it also be possible to lock the screen layout as a preference?
keqingsong
Can you give us an example of what you're experiencing? A screenshot of a before and after state would be super helpful.
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
BrianM_12
In order to perform a nice clean log off I expose the projects display
so that I can monitor the file saving process as I shutdown. I save the
open file manually and watch the indicator on the applicable file until
it stops rotating and then I shut down the program.
When I am working I minimise the project display and move the tool menu
to the very top of the screen in the gray area.
I find that when I logon for a new session the project display appears
in the correct place to allow me to open a project but the tool bar menu
has returned to what seems to be a default position on the screen.
It would be good if we could put the tool bar menu in our favorite
position and have the preferences file remember this position through a
shutdown.
The system obviously remembers such settings as the default units during
shutdown so I was hoping the tool menu bar could be made to operate the
same way.
Thank you, Brian
This relates to a more general wish: Saving individual Workspaces including position of docked UI elements and Ribbon-customizations.
