Variables in parameter equations?
Is there a way to use variables in parameter equation? I can't get it to work...
Pavel_Holecek
is this what you are looking for? - http://fusion360.autodesk.com/learning/learning.html?guid=GUID-715E7B9F-453B-4660-BC8B-E0C7B0E2ED80
Regards
Pavel Holecek
Autodesk QA team
HughesTooling
You need to make sure the units match in your parameters. Can you attach a screengrab of what you have.
This link to help on parameters might help,
Mark
Mark Hughes
Owner, Hughes Tooling
I thought I did attach a screencast. Not sure why it didn't show up. I'll try again.
I was originally trying to do the pythagorean theorem so the units should have worked out. Looks like I can get it to calculate if i turn off the units but now I can't figure out how to use it as a dimension as it is unit-less.
HughesTooling
You need to make your parameter unitless by dividing by -1in, like this.
To change a unitless number to the units you are working with multiply by 1unit. You can for example have a unitless parameter and mutiply by 5in to convert to inches so if you have a unitless parameter Length and you're adding a new parameter that's in inches you can use Length * 5in.
Mark
Mark Hughes
