Projected lines in a bowl
I projected lines into a bowl. I broke the links, but I am not sure how to select it like you normally select sketched lines...
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 community! Smiley Happy
May I know what you expect through it? I would like to know your final model.
I look forward to your reply.
Many thanks,
oh yea, it is supposed to create indents in the sphere of every other rectangle to create a handmill grinder. I would create a second piece that fits the top with the same indents so when you put them together, and you turn them independent of each other, you can grind coffee.
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for prompt replying. I think we are in the same timezoneSmiley Very Happy
I think it would be easy to create the body you want if we use "Patch" environment.
I'm sharing way  if I missed something, please let me know. I'll reply right away.
Create indents body
Many thanks,
Oh, ok, great!! thanks, I will check it out! Thanks for your help!
