Using part motion to design additional parts.
How do you create geometry for one part that is defined by the contact surface with other parts that have a predetermined design and movement path?
Bud_Schroeder_ADESK
Hi Jeremy,
Welcome to the A306 Forum. Are you maybe looking for the Fusion Forum? Let us know and we will move your post to that forum.
Thanks for getting us an update.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Join the AutoCAD Customer Council Beta Program.
Please do. Thanks.
innovatenate
Autodesk Support
Autodesk Support
There's a postional modeling technique outlined in a youtube video below.
https://www.youtube.com/watch?v=TOh1m4Yp4bk
It's similar to the solution discussed in the below forum post.
https://forums.autodesk.com/t5/design-validate-document/possible-to-make-a-split-bodies-or-cut-in-mo...
You use the capture postions command (formerly known as snapshot) to record positional information in the timeline. At each step in the timeline you can create geometry or sketches, etc to create features/operations that do what you need.
It would be really helpful to have a sample model or something in mind.
I hope that helps! Let us know if you have any questions!
Nathan Chandler
Principal Specialist
