Fusion 360 - Can I override the mass of an object?
Message 1 of 14
Easy question
Lets say I have a motor that I dont want to spend hours painstakingly modeling perfectly to use it in an assembly, in solidworks I could draw the outside of the motor, select the component, and set its mass to a given value, now I may get weird simulation results, but it works for calculating the total assembly mass (what I care about)
now in fusion360, it /appears/ the only way I can do this is to get the volumn of the body, then calculate out what its density should be, then apply a custom material to it, kind of a pain in the butt, and it fills my materials page with tons of useless materials.
So long story short, is there a way of straight overriding the mass of a component without going through all those steps?
Replies (13)
Message 2 of 14
jeff_strater
Today, no, there is no way to override the mass properties on a component.
I checked, and today, there is no idea station entry for this.  Please feel free to create one here
Jeff
Jeff Strater
Engineering Director
Message 3 of 14
I_Forge_KC
Please add this to the idea station!
K. Cornett
Generative Design Consultant / Trainer
Message 4 of 14
Yeah I mentioned that in the 2nd paragraph, you can get around the problem, but it would be nice to not have the problem 🙂
Message 5 of 14
Message 6 of 14
jarosascordova
Still not possible in 2022 😞
Message 7 of 14
TheCADWhisperer
You can do this in Autodesk Inventor Professional (years ago - before Fusion even existed).
Maybe the Fusion developers should walk across the hall and ask their teammates how it is done.
Message 8 of 14
jarosascordova
Yeah, I used to use SolidWorks in university and this was a standard feature. It is pretty useful when you do a lot of aeronautical work and have to calculate CGs.
I found this script that can be used as a workaround, not ideal but easier than doing it yourself every time.
Message 9 of 14
rushabhthakkar_910
This should be implemented in Fusion.
Because in Solidworks I can just create a rectangular part and assign it the weight I want rather than having to model it.
This comes very handy when you  need a rough C.G. of a Part/Assembly but don't have time/Skill to create the design.
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 10 of 14
jarosascordova
Does the idea forum still work? Maybe we should make a new post about it
Message 11 of 14
rushabhthakkar_910
Yes it still works.
Thanks and Regards,
Rushabh Thakkar.
Message 12 of 14
jarosascordova
Seems to be archived. Now there is  a "Feedback forum" but it does not let me post there 😞
If anyone happens to know how to contact a developer, it'd be nice if they could ask if this feature is under consideration. It would really help a lot with CG-sensitive work.
Message 13 of 14
rushabhthakkar_910
Post it in Feedback Forum.
Thanks and Regards,
Rushabh Thakkar.
Message 14 of 14
jeff_strater
"under consideration":  yes.  On any immediate roadmap: no, not that I am aware of.  It is a valid requirement, but, because there is a workaround (custom material with a custom density), I suspect it is pretty far down the priority list.
Jeff Strater
