Good afternoon,
The entire question is basically in the title, is there a way i can use a fit point spline as an axis for an eclipse, or is there a different method of achieving the same effect? the goal is to create a sketch that resembles a potato chip.
Good afternoon,
Extrude the Spline as a Surface Body.
Use the Ellipse to Trim the Surface Body.
If you want compound curve - then the process is a bit more involved.
Here you go:
