Using a Fit point Spline as an axis for an eclipse/circle
2 REPLIES 2
merijn.timmer
289 Views, 2 Replies
merijn.timmer
Observer
Observer
Good afternoon,
Frontal viewFrontal viewAngled viewAngled view
The entire question is basically in the title, is there a way i can use a fit point spline as an axis for an eclipse, or is there a different method of achieving the same effect? the goal is to create a sketch that resembles a potato chip.
Good afternoon,
Labels (1)
2 REPLIES 2
TheCADWhisperer
Extrude the Spline as a Surface Body.
Use the Ellipse to Trim the Surface Body.
If you want compound curve - then the process is a bit more involved.
merijn.timmer
Observer
Observer
Here you go:
Here you go:
