upload icon is greyed out and cannot create a new folder
Message 1 of 10
Good day for whatever reason the upload button is greyed out , therefore cannot upload any design, moreover when I try to create a new project the message is operation failed.
Marco
Replies (9)
Message 2 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 Community!
From the looks of it, it does not look like you are on the latest version of Fusion 360. Just to check - did you download Fusion from the App Store or from the Autodesk website? I do note that the Autodesk website version should be 2.0.2676. You can verify this in Fusion by going to the Help menu in the top-right corner and selecting About. While you are in this menu, what does it say next to Active Plan? A lot of times you cannot create new data as a resultant of an expired trial for example.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 3 of 10
dskinnerWMQCL
 I'm having the same issue, my version is 2.0.2865 and my Active Plan says Ultimate, Student.
Any ideas?
Message 4 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Hi @dskinnerWMQCL,
Can you post a screenshot of what you are seeing?
James Youmatz
Message 5 of 10
dskinnerWMQCL
Message 6 of 10
dskinnerWMQCL
And I suppose this may be part of it too.  It appears that it's not saving to the cloud.
Message 7 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Hi @dskinnerWMQCL,
Can you send me your diagnostic log files from the help menu? I wonder if Fusion cannot connect to the internet and this is what is causing these issues. Just to check - have you tried restarting your computer and opening Fusion back up. Same issue?
James Youmatz
Message 8 of 10
dskinnerWMQCL
After a reboot it is still the same.
Message 9 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Hi @dskinnerWMQCL,
I see the following error message from your log files:
ERROR: Response Data: INTERNET_DISCONNECTED
This seems strange to me - as my guess is you would have noticed if you could not access the internet. This does make sense with what we are seeing however. It almost seems as if Fusion thinks it is in offline mode.
Let's try this - can you please try the steps in this guide here to delete the loginstate.xml and then relaunch Fusion and sign back in. Does it let you sign in? Can you now upload? If not, can you try resetting your network router and trying again?
James Youmatz
Message 10 of 10
dskinnerWMQCL
After deleting the file and restarting the program, I still had to tell it to go to offline and then back online before it "woke up" but it's running fine now.
Thank you
