How do move a set of sketch points I imported from SVG
This is a bit of an odd one. I imported an SVG logo into a sketch, in order to cut the logo out of an acrylic panel. That worked fine, and I could resize and position the imported curves.
Now though, I want to move them and scale them, but can't seem to do so.
Everything is constrained, apart from the bits making up the raspberry. If I area-select all the nodes making up the logo and try to [M]ove them, only the move-control widget moves.
What is the best way of taking an SVG, and either incorporating it into a sketch, or adding it as a new one to push/pull a hole in something?
This is the part:
HughesTooling
Green curves are locked, you need to select them and click Unfix on the sketch palette.
Mark
Mark Hughes
Owner, Hughes Tooling
Aaah, knew it had to be something daft. Thanks for the quick response!
