Keeping components in place when making parameter change
I'm trying to keep some drawn in place parts with a slider joint to stay in place when a parametric change is made in relation to the size of the part that they are joined to. They don't want to move with the change. How do I keep them in place on the part when the parameters are changed and still use the slider joint?
Appreciate any help...thank's
Dave.
jeff_strater
If you can share the design, and a screencast of what you see, it's more likely that someone will help you.  Most likely, it is the way the slider is defined, or the nature of the change.
Jeff
Jeff Strater
Engineering Director
