updating reference failures
SEIZMICdesign
Message 1 of 13
SEIZMICdesign
I'm sure there's a way to do this but I can't seem to figure it out. Some sketches have changed and I guess the original reference points have been "forgotten". How does one go about "reminding" the sketch where it's references are?
Thanks to all who have helped me figure this stuff out so far. Couldn't have done it without ya!
Replies (12)
Message 2 of 13
masa.minohara
Hi @SEIZMICdesign,
Thank you for posting this! Would you be able to share the design with me? I would like to take a closer look at the issue.
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 13
SEIZMICdesign
Sorry it took so long, here's the link:
http://a360.co/2a3U2gR
Haven't had a chance to work on it much, last week was crazyville. Smiley Frustrated
Message 4 of 13
masa.minohara
Thank you for your response. Could you turn on the Allow item to be downloaded option? I am unable to download the file.
Masanobu Minohara
Message 5 of 13
SEIZMICdesign
Always forget that! should be on now.
Message 6 of 13
masa.minohara
Thanks! I will take a look and get back to you as soon as I have an update!
Masanobu Minohara
Message 7 of 13
SEIZMICdesign
Thank You! It would be nice if the original reference could be listed in the "Reference Failure" warning. It said "point" so I guess that's what threw me off the track. Even if it said "surface" that would have gone a long way in helping me identify how to fix the problem! It seems like the name of the reference could be in there, but maybe that's not feasible.
Message 8 of 13
CarlFrischmuth
what happened with this??
Message 9 of 13
CarlFrischmuth
It seems that there is no way to clean up reference failures in some sketches, they stay dirty yellow forever, if the face reference upstream is lost for a project / intersect as there's no way to select the cached or old bad geometry to break links or delete it to tidy it up?
This isn't really that good guys, can we get some way to clean up old / outdated sketch reference failures e.g. from project>intersect (where the upstream face selection is gone)..
there should be some way to delete these old references out or purge / clear fusions use of old cache geometry in sketches  especially if the sketch is actually manually fixed up but the silly old reference fail still hangs around.
Message 10 of 13
Beyondforce
Hi @SEIZMICdesign,
Do you remember, which body have you deleted? When it says "Cache is used", that means you have deleted a body/sketch/plan which have been used as a reference.
If you can Undo the deletion, that will be great. If not, you will have to break the link inside the sketch (in yellow) or roll back the time line and re-create the body/sketch/plan that you have deleted (that will not be fun to do).
Please watch this: https://www.youtube.com/watch?v=zZfNC4R2sg8
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 11 of 13
masa.minohara
Hi @CarlFrischmuth,
I'm sorry I should have posted here but we communicated through private message and sent SEIZMICdesign a fixed design. I needed to redefine sketch planes.
Masanobu Minohara
Message 12 of 13
CarlFrischmuth
thanks for the reply Masanobu Minohara, its good that the other issue was fixed with redefine sk planes 🙂
Should we log a bug for the inability to purge or otherwise delete / clean out bad reference data from sketches that are impossible to clean up and remain yellow?
thanks,
Carl
Message 13 of 13
daniel_lyall
Ben when you remove ref data you can rebuild it to a new plane or if it's in a component you re ref it to the components origin. It is something to be carefull with and you should do it first before deleting.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
